Hardware
Hardware required for successful installation of Shoper 9 depends on various factors that include inventory size and volume of transactions recorded. Refer the following table for more.
Server (HO)
Particulars |
Recommended Configuration |
Processor |
Intel Xeon 3 GHz or greater |
RAM |
2 GB (4 GB for more than 50 Stores) |
Hard Disk space |
160 GB |
Backup device |
DAT Drive |
Network |
100 Mbps, Switched |
Server (POS)
Particulars |
Processor |
Pentium D, 2.4 GHz |
RAM |
512 MB (Server with MSDE) 1GB (Server with SQL Server) 2GB (Server with SQL 2005 Std/Enterprise/Express Editions) |
Hard Disk space |
160 GB |
Backup device |
DVD-Writer |
Network |
Printer |
TVS MSP 240/250 or Epson LX 300+ (Parallel Port, DMP) |
Client (HO & POS)
Particulars |
Processor |
P-IV 1.8 GHz |
RAM |
512 MB |
Hard Disk space |
40 GB |
Network |
Printer |
Devices Supported
Dedicated to enhance your billing experience, Shoper 9 is compatible with and supports various input/output devices, and POS machines. It can also be customized to support new devices and models. Be it dynamic customer display units, electronic cash drawers, magnetic card readers, and even barcode scanners, Shoper 9 supports it all, reducing your retail office space. You can also use portable data terminal devices, to enter stock data wirelessly. Print receipts, slips, and barcodes.
Architecture
Shoper 9 encompasses Shoper 9 HO and Shoper 9 POS to meet all your requirements from a single retail store to an extensive retail network. Install Shoper 9 HO at your head office or primary control center to monitor all Shoper 9 POS installed at each retail and distribution center.
With Shoper 9 architectural flexibility you can,
- Command over complete business management and performance analysis.
- Generate reports without connectivity necessities.
- Continue data communication using FTP, e-mail, HTTP, or manual copy.
Customisation
Shoper 9 Retail Solutions can be customised by Tally Integrators to meet specific requirements. Catering to the constantly evolving business needs, Shoper 9 is packaged with a customisation framework designed to ensure easy handling of database connection and common features.
- You can develop new reports with standard Shoper report headers, and Enhance your interface at the line level through customizable buttons.
Interfaces
Eliminate the need to recreate data for external applications. With Shoper 9’s flexible and configurable interface frameworks, share and receive data from applications like SAP, Tally.ERP 9, and other custom/legacy softwares, in the required format. (.txt, .csv files, HTML, XML and spreadsheet formats).
